Trim value could not be measured properly - 9S08LL16
1,059 次查看
DavidLuna
I'm using MC9S08LL16 but can't go so far; I run a "Test" program
to check the TOD module, but when I try to run it again failed.
After a while this message was displayed:
" The trim value could not be measured properly"
I tried configuring the external and internal oscillator but both had
the same result.
So, this far I have 4 useless MCUs
I'm working on CW 10.2
Could someone give me some advice to solve this?
Why is it happen??
And how to recover the MCUs??
标签 (1)
标记 (1)
0 回复数
