Serial Bootloader MC9S08AC16
willyrey
Hello
We are using the bootloader software from AN2295 Version 10.0.13.05. For the MC9S08AC16 we are using the lastest ASM software from the same package. The software could be loaded on the device with no problems. Running the software will not result in a Connection. The master software got several transmitted code from 0x01 up to 0xb1. It looked that the device could not trim the exact value for the busfrequency. Attached you will get a screenshot of the master software. By the way the baudrate is 9600. What could be done for adjusting the slave software on the device for proper working? Thank you for your support.
Best regards, Willy
