SL3S4021 i2c Command Registers
2,001 次查看
zacck
Hello, I am building a race timing system around the SL3S4021 UCODE i2c Chip, However after going through the product datasheet I can't seem to locate which register addresses I need to use when sending EPC Global commands to the device, could someone please point out this information to me. I should add I tried getting the Errata Sheet, however that is covered under NDA and I have been informed to open a ticket so at to access it. Thank you so much for the time and I look forward to hearing from you. Kind Regards
标记 (1)
1 回复
1,932 次查看
Jonathan_Iglesias
Hi @zacck
in order to generate an NDA  this is not the place to create a case, https://www.nxp.com/support/support:SUPPORTHOME?tid=sbmenu
here you can create a ticket and please put in the  subject that you request an NDA.
Jonathan
