SD card data logger
SD card data logger
mimco
I have read NC103_ReadandWriteSDCardoverUSBUsingJM60andAnySPIModule.pdf document. In this document is described FAT Demo Using USB TerminalSPI aplication, which implements FAT16 driver and SD card driver into JM60 MCU. I would build GPS data logger, which will store GPS position data into micro SD card. Please, where cann find FAT16 driver or whole project described in NC103... document? SD card driver i found e.g. in DRM104SW.zip. And I have another question, it is possible using micro SD card instead SD card? Because micro SD card has 8 pins, while SD card has 9 pins?
Regards mimco
rRr
PS: I'm sorry for my poor English.
PO220
HI
You can find Fat.c et Fat.h in FLEXISJMSD_DATALOGGER
David
