Programming using CyclonePro over Ethernet
2,229件の閲覧回数
PhilG
I am trying to use the CyclonePro programmer over an Ethernet connection.
When it is on our local network I can download images into it OK.
I am trying to use it over an internet connection. I have an outstanding support request with PEMicro but I have had no response. I have confirgured my firewall and port forwarding settings according to PEMicro UDP ports which are used. But I am not getting any response from the programmer. I have tried monitoring the Ethernet packets and the correct data is coming through the firewall from the internet.
Can anyone help me and suggest any changes to my configuration?
I know I have placed this message in the 8-bit forum, but could not think where to put this message.
Phil Green
1,195件の閲覧回数
Alban
Senior Contributor II
Hi PhilG,
"Please hold the line when I'm trying to connect you..."
Cheers,
Alban.
