Programming a MC9S08AC128, when I erase a sector with the 0x40 Sector Erase Command upon completion of the erasure FACCERR in the FSTAT register always gets set. This shouldn't be.
1,547 次查看
PabloMac
标记 (4)
1,323 次查看
ZhangJennie
hi,
attached is 9s08aw60 flash routine demo code. i suggest you refer it to make yours.
can this help you?
Jennie Zhang
