Programming TRIM Values In Flash
2,134件の閲覧回数
Davo
I would appreciate if anyone could share the assembly code for storing the ICG TRIM value in flash.  I could write it but I'm sure this has been done a thousand times before.
I am using both the HCS GB60 and also the QG8.  I realise the code would be different for these parts.
thanks
David
1,194件の閲覧回数
peg
Senior Contributor IV
Hi David,
Why not just do it with your flash programmer?
AN2496 and its accompanying software shows you how to determine the correct trim and then programme it in yourself. This should give you all you need.
Accessed from the GT product page.
