PWRLIB IN 13192SARD
PWRLIB IN 13192SARD
belie
Hi Sir:
    We used 13192 sard and 13192 evb to develope some products.Our customer need low power in zigbee products. So, I add the PWRLIB to zigbee stack as you
told me ,and configure it with keyboard wake up .
   And yes ,the power is very low.But sometimes the mcu will die when I press the keyboard to wake up the system.I do many try but still don't know why ,
Hope someone can give me some advice.
  Thanks a lot
  China
  Belie Song
stevasway
I saw the same problems using SMAC with an example appeared in SMAC4.1a version called SimpleNetwork. Do you find a solution?
Stevasway
