OpenSourceBDM driver issue??
3,019件の閲覧回数
baddad
I have built the OpenSourceBDM, but get an error when I try to launch "set GDI" in the debugger.
"... GDI.dll or one of it's components not found or loaded.  System Error 126 - specified module could not be found."
Any idea what may be causing this?
Brian
Message Edited by baddad on 2006-07-11 08:00 AM
1,144件の閲覧回数
peg
Senior Contributor IV
Hi Brian,
You have followed section 6.3.1 of the manual and specified where the DLL is. Yes?
Have heard of problems when locating it obscurely. I have the DLL in the gdi directory below the prog directory where hiwave.exe is located.
Give it a go here.
Regards David
