Greetings,
I would not suggest the USB BDM Multilink anymore. It will be going out of production very soon.
Please look into getting our USB Multilink Universal hardware interface:
P&E Microcomputer Systems - USB Multilink Universal - USB Multilink Universal All-In-One Development...
Tech summary can be found here:
Not only will this interface work with HCS08 architecture, but you are future proofing your company to allow flash programming on other Freescale devices including Kinetis ARM devices.
Note, if you have a large production line, I would suggest getting some of our other hardware that is much faster and more convenient. Please let me know how many devices you plan on producing per day and I can suggest you better options.
Codewarrior can be used to download the S19 file with the USB BDM multilink or USB Multilink Universal. But you will be working on a large IDE that has capabilities of creating new projects, flash programming, and debugging. However, if you are on a production line or in need of a smaller application that only flash programs the chips, then I suggest you get our PROG software for HCS08 architecture:
P&E Microcomputer Systems - PROGHCS08 - 68HCS08 Flash/EEPROM Programmer Software - HCS08, Flash/EEPR...
All of our tools work great with the latest operating systems.
Let me know if you have any more questions or concerns.
Takao Yamada
