Mini test program
Mini test program
thngkl
Hi, i new to the programming of MC9S08GT series. Is there any sample program or source code available for the simple transmission and reception of data? Thanks
J2MEJediMaster
Specialist I
If you've obtained Codewarrior for this part, check out the directory (Codewarrior_Examples), which has a medley of example programs with source code. Or, try entering the processor number into the keyword search at the top right of this page and see what application notes show up in the search results.
---Tom
Message Edited by J2MEJediMaster on 2006-09-06 11:45 AM
