MC9S08QE8 External Crystal Setup in PE
1,989 次查看
aggiemundo
I'm currently trying to generate my initialization code using Processor Expert, and would like to have the ability to use an external crystal to generate a very accurate 57600baud rate on my UART.  So far I have been unable to find anywhere in the CPU bean (or any other bean) where I can do this.
I would have expected that I would be able to select an external clock source in the "High Speed Mode->High Speed Clock" dropdown, but it only allows me to select "Internal Clock".  What goofy mistake am I making?  Thanks!
标签 (1)
2 回复数
1,226 次查看
ProcessorExpert
Senior Contributor III
The property that you searching for is "External Clock" and it is available after unfolding "Clock settings" group.
best regards
Vojtech Filip
Processor Expert Support Team
1,226 次查看
aggiemundo
Yikes, I have no idea how I missed that the first fifty times!  Thanks, and terribly sorry for the brain-dead question!
Delete post, ban user, revoke engineering degree! :smileyhappy:
