MC9S08PA60 can not work properly
fanding
I'm developing a product by using the Freescale's MC9S08PA60 microcontroller. input and output port is not working; MCU power supply is normal, using the internal oscillator, the RTC module can normal work,  this is what causes?
vicentegomez
Please check that you have set the Port x Output Enable Register (PORT_PTxOE) or the Port x Input Enable Register (PORT_PTxIE)
I hope this will help you.
