Hi jackabo
it is very simple to connect a LED to a microprocessor (MPU). A LED acts like a lamp, BUT you have always to connect a resistor in series with a LED!!! The resistor as to have a value of 2200 OHMs or 2.2kOhms. Simply connect the LED with the anode (usually the longer leg) to a GPIO (general purpose input output) the cathode on the resistor and the hter leg of the resistor to GND. That should work. Then you have to program your device to set the bit you have chosen for the LED to be set to HIGH and the LED should turn ON.
Saluti Joerg
PS. if you like a simple OS try EBS08
infos here
http://forums.freescale.com/freescale/board/message?board.id=8BITCOMM&message.id=4284;Message Edited by joerg on 2007-02-0207:09 PM
Message Edited by joerg on 2007-02-0207:11 PM
Message Edited by joerg 3 times because the automatic stuff does NOT work! on 2007-02-0207:12 PM
Message Edited by joerg on 2007-02-0207:13 PM
