MC13213 schematic or gerber file
4,290件の閲覧回数
Mercurio
Hi evreyone, i need to find some guide line about MC13213. I need to build a ZigBee device with a bipolar antenna and i need some exemple of schematic or gerber file to know which components i need and how to make right connections.
Can anyone help me?
Thank's to all.
Ciao
4 返答(返信)
2,051件の閲覧回数
J2MEJediMaster
Specialist I
Enter your part number in the "Enter Keyword" search entry at the top right of this page, and it will call up a bunch of entries for the MC13213. Scroll down until you find "1321xNCB Reference Design for the 1321x-NCB Dev Board". This archive file has a schematic and gerber files for a reference board using the part. This might not be exactly what you want, but perhaps it will get you started.
Good luck!
---Tom
2,051件の閲覧回数
Mercurio
Thank you very much, i've got yet something like that. What i need is an example using bipole antenna, but i can't find nothig with bipole.
Anyway thank you so much :smileywink:
2,051件の閲覧回数
Ware
The 13192-SARD board used a bipole antenna.  It used the MC13192, but the interface to the antenna should be the same as the MC13213.
 - Ware
Message Edited by t.dowe on 2009-09-22 11:27 AM
2,051件の閲覧回数
Mercurio
Thank you so much :smileywink:
Ciao
