MC13213- Direct data communication between master and slave in MAC code base.
AmZig
Hello everyone,
I am trying to implement a direct data communication between a master and slave device. I am using non beacon mode , and i dont want to use Polling feature of EX 6a and Ex6b. I just want to do the direct communication , assuming that my slave is on and waiting for a reply from master for the sent data(from slave). I did this in Polling base example. But i dont need that now , and when i tried this in direct way. It doesnt work. So , kindly guide me as i am running out of time for my submission.
AmZig.
Mads
AmZig,
set the RxOnwhenIdle attribute to TRUE after association on the RFD (6b).
on the Coordinator, remove the Indirect Tx option flag in the mcps-data.request (6a)
BR,
Mads
AmZig
Hello Mads,
Thank you very much , it worked for me..
AmZig
