MC1321 Evaluation Board
saurabh
I received the evaluation board for MC1321 a few days before. I have flashed a sample code to check the  data conversion using ADT. I later came to know that the evaluation board comes with pre-flashed code. In that one of the SRBs work as the radio and the other can be connected to the PC.
Does any one know where can I get the pre flashed code so that I will reflash it to that binary.
Mads
Contributor V
Saurabh,
the Binaries is not available but the source code is. Just go to www.freescale.com/zigbee and download the Beekit.
you can compile the SMAC applications that are in the boards pre-flashed.
you can find an evaluation or limited edition compiler on www.codewarrior.com
Br,
Mads
saurabh
Thanks for your prompt reply. I could find the sample code in the beekit package. Thanks.
