ISC (I2C) Assembler sample code for MC9S08AW32
1,690 次查看
KarDan
Good afternoon guys,
I use the following microcontroller for my current school project: MC9S08AW32.
Do you have sample assembler code for using the internal ISC (I2C) interface on the microcontroller?
Would like to read out an ISC sensor now, but don't know how to proceed ... do you have a template?
Would be grateful to you.
With best regards
1,672 次查看
vicentegomez
Sorry in ASM I do not have a sample code, but you can check the following application note and you can use the disasamble option in code warrior to change the C code to ASM
https://www.nxp.com/docs/en/user-guide/HCS08QRUG.pdf
and you can find the sample code in
https://www.nxp.com/docs/en/user-guide/QE128QRUGSW.zip
