I2C flash programmer
PW_CTL
Hi to all. I´ve seen some functions in processor expert to write flash at execution time. Joining it with an i2c driver... will be possible an i2c on board real time programmer? What u think about?
celsoken
Contributor V
Dear PW,
I don't know if I got you right, if you are programming internal flash or external IIC flash. Both are possible but the first one has limitations depending on the architecture you're using, e.g. you need to be executing in RAM in order to program flash.
Cheers,
Celso
