I2C communication using HC08
1,661件の閲覧回数
lukasztrojanows
Hi. Did anyone use the MC68HC908QB8 to establish communication with a peripheral device using I2C, and would be so kind to share the code?
タグ(2)
1,434件の閲覧回数
CustomSarge
Howdy, I use this code I wrote before any 9S08s had an I2C module.
This copy is from a 9S08AC16 32pin QFP, managing an I/O expander, 2 Digital pots, 3 DACs & a 24C02 flash.
DPots & DACs are MicroChip series.  I/O expander is NXP.  Good Hunting...   <<<)))
;* Port C: b0;1=I2C SCl;SDa /flash(a0)/10k DPot(52)/100k DPot(54)/
;*         compressor DAC(c0)/balance DAC(c1)/LCD contrast DAC(c2)
; I2C direct constants
flhadr  equ     $a0             ;flash RAM address (LSb=R/W*)(=0)
tnKdev  equ     $52             ;10k DPot Amp device addr (LSb=R/W*)(=1)
hnKdev  equ     $54             ;100k DPot Amp device addr (LSb=R/W*)(=2)
rlydev  equ     $c0             ;relay driver/Refl % selector
rlybas  equ     $05             ; relay base: 00=Off, 01=On, 10=70%, 11=20%
baldev  equ     $c2             ;DAC OptoFET LED driver/Balance
condev  equ     $c4             ;DAC LCD display contrast
; I2C  RAM
devreg  ds.b    1               ;RAM data page base addr
devadr  ds.b    1               ;I2C DPot address
;Initialize
;* read parmset from flash, parms all stay in these spots
        jsr     I2CStp          ;send a couple Stops to clear I2C protocol
        jsr     I2CStp
;* read flash parms
        ldhx    #prmtnk         ;set parameter base address
        mov     #flhadr,devadr  ;set device address
        mov     #$00,devreg     ;set flash addr
        jsr     RdPage
;        ldhx    #RefTbl         ;lamp life ref table
;        mov     #$10,devreg     ;set flash addr
;        jsr     RdPage
;        mov     #$20,devreg     ;set flash addr
;        jsr     RdPage
;        mov     #$30,devreg     ;set flash addr
;        jsr     RdPage
;* init relay driver, Duty Cycle parms NOT USED, Init as proof
IniRly: jsr     I2CSrt          ;xfr START
        lda     #rlydev         ;put/send devsel/addr (LSb=W*)
        jsr     I2CTx8
        jsr     I2CRx1          ;get NAck/Ack* (NAck=error)
        bcs     IRDErr          ;C=1: error
        lda     #$11            ;register select & autoincr
        jsr     I2CTx8
        lda     #$00            ;register PreScale 0 = max freq
        jsr     I2CTx8
        lda     #hld_dc         ;register PWM 0 = Hold %
        jsr     I2CTx8
        lda     #$00            ;register PreScale 1 = max freq
        jsr     I2CTx8
        lda     #cls_dc         ;register PWM 1 = Close %
        jsr     I2CTx8
IRDErr: nop                     ;error trace trap
        jsr     I2CStp          ;nml exit as stop
;* init balance DAC, direct I2C calls: addr & cfg only
        jsr     DacRst          ;reset DACs' I2C
        jsr     I2CSrt          ;xfr START, ALT entry/set unit addr
        lda     #baldev         ;put/send devsel/addr (LSb=W*)
        jsr     I2CTx8
        lda     #cfgDaI         ;page=reg select & cfg: DAC Config
        jsr     I2CTx8
        jsr     I2CStp          ;xfr STOP
;* init contrast DAC, direct I2C calls: addr & cfg only
        lda     #condev         ;put/send devsel/addr (LSb=W*)
        jsr     I2CTx8
        jsr     I2CTx8
; LCD, DAC & DPot ~ I2C Manager Routines
;* RdPage - get <gpctr1>(16) bytes, put to (H:X)+; page base in devsel & chrtnk
RdPage: mov     #15,gpctr       ;16 bytes (15 loops + last)
RdAddr: jsr     I2CSrt          ;xfr START, ALT entry/read unit addr
        lda     devadr          ;put/send devsel/addr (LSb=W*)
        jsr     I2CTx8
        bcs     RxErr           ;C=1: error
        lda     devreg          ;page base addr 7-0
        jsr     I2CTx8
        jsr     I2CClk
        jsr     I2CClk          ;pause for page addr write to take
        jsr     I2CSrt          ;send ANOTHER START after page addr write
        ora     #$01            ;chg to Read
        jsr     I2CTx8
SRDRd:  sta     SRS
        jsr     I2CRx8          ;read a byte
        clc                     ;clr Carry & send as Ack
        jsr     I2CTx1
        sta     ,x              ;save data to ram
        aix     #1              ;inc index
        dbnz    gpctr,SRDRd     ;dec ctr & loop
        jsr     I2CRx8          ;read last byte
        sec                     ;set Carry & send as NAck
        jsr     I2CTx1          ; not really a NAck: 1 bit time B4 stop
RxErr:  jsr     I2CStp          ;xfr STOP
        sta     ,x              ;save last of data
        aix     #1              ;inc index
        rts
;* WrPage - put <gpctr>(16) bytes, from (H:X)+; page addr in devreg
WrPage: bsr     Wr8Flh          ;AT24C02 Writes 8 bytes/page
        lda     devreg          ;next page
        add     #$08
        sta     devreg
        bsr     Wr8Flh
        rts
Wr8Flh: sta     SRS             ;Page Writes to FlashRAM only
        bclr    i2cWC,PTGD      ;low enables write to flash
;* Note: flash roms can have 8/16/32 byte pages
WrAddr: mov     #8,gpctr        ;8 bytes
        jsr     I2CTx8
        bcs     TxErr           ;C=1: error
        lda     devreg          ;RAM data page base addr
        jsr     I2CTx8
SRDWrt: sta     SRS
        lda     ,x              ;put/send byte
        jsr     I2CTx8
        aix     #1              ;incr index
        dbnz    gpctr,SRDWrt    ;dec ctr, send all
        pshh                    ;save source addr
        pshx
        ldhx    #wrtrom         ;24C01 10mS write time
SRWDly: sta     SRS
        aix     #-1
        cphx    #0
        bhi     SRWDly
        pulx                    ;restore source addr
        pulh
TxErr:  jsr     I2CStp          ;nml exit does 2 stops: no problem
        bset    i2cWC,PTGD      ;high disables write to flash
        rts
;  WrByte: Standard DPot setting: devadr, devreg=dev, reg sel, gptnk=value
WrDPot: jsr     I2CSrt          ;xfr START
        jsr     I2CTx8
        bcs     TxBErr          ;C=1: error
        lda     devreg          ;register select
        jsr     I2CTx8
        sta     SRS
        lda     gptnk           ;put/send byte
        jsr     I2CTx8
TxBErr: nop                     ;error trace trap
        rts
;  WrtDAC: devadr, devreg=register & value MSn, gptnk=value 2Sn/LSn
WrtDAC: jsr     I2CSrt          ;xfr START
        jsr     I2CTx8
        bcs     TxDErr          ;C=1: error
        jsr     I2CTx8
        sta     SRS
        jsr     I2CTx8
TxDErr: nop                     ;error trace trap
        rts
; Low Level bit-bang drivers ******************************************************
;* I2C routines: read byte/bit, start, stop, clk delay, write byte/bit
I2CRx8: bsr     I2CRx1           ;Rx byte to A, get b7 in C
        rola                     ;C->b0
        bsr     I2CRx1
        rola                     ;C->b0, b0->b1...etc
        bsr     I2CRx1
        rola                     ;C->b0
        bsr     I2CRx1
        rola                     ;C->b0
        bsr     I2CRx1
        rola                     ;C->b0
        bsr     I2CRx1
        rola                     ;C->b0
        bsr     I2CRx1
        rola                     ;C->b0
        bsr     I2CRx1
        rola                     ;C->b0
        rts           ;----------
I2CRx1: sta     SRS
        bclr    i2cDta,PTCDD     ;Rx 1 bit to Carry, chg to In
        bsr     I2CClk
        bset    i2cClk,PTCD      ;clock high
        bsr     I2CClk
        sec                      ;init Carry=1
        brset   i2cDta,PTCD,IRx_0 ;=1: go clk
        clc                      ; else: data = Lo
IRx_0:  bsr     I2CClk
        bclr    i2cClk,PTCD      ;clock low
        bsr     I2CClk
        bclr    i2cDta,PTCD      ;reset as low
        bset    i2cDta,PTCDD     ;chg to Out, data out reg bit=0
        bsr     I2CClk
        rts           ;----------
;* I2C Common routines: start, stop, clk delay
I2CSrt: bset    i2cClk,PTCD      ;Start: inits a xfer
        bset    i2cDta,PTCD      ;enters w/clk & data High
        bsr     I2CClk
        bclr    i2cDta,PTCD
        bsr     I2CClk
        bclr    i2cClk,PTCD      ;exits w/clk & data Low
        bsr     I2CClk
        rts           ;----------
I2CStp: bsr     I2CClk           ;Stop: closes a xfer
        bset    i2cClk,PTCD      ;enters w/clk & data Low
        brn     I2CClk
        bset    i2cDta,PTCD      ;exits w/clk & data High
        brn     I2CClk
        rts           ;----------
;* Delay timer
I2CClk: mov     scltnk,bittmr   ;load clk count: 400kHz=2.5uS
I2CCLp: sta     SRS
        nop
        dbnz    bittmr,I2CCLp    ;=3+1+5 :: ct=3->27cyc
        rts           ;----------
;* I2C Tx routines
I2CTx8: asla                     ;Tx byte in A, b7->C, 0->b0
        bsr     I2CTx1           ;send bit in Carry
        asla                     ;b6->C
        bsr     I2CTx1
        asla                     ;b5->C
        bsr     I2CTx1
        asla                     ;b4->C
        bsr     I2CTx1
        asla                     ;b3->C
        bsr     I2CTx1
        asla                     ;b2->C
        bsr     I2CTx1
        asla                     ;b1->C
        bsr     I2CTx1
        asla                     ;b0->C
        bsr     I2CTx1
        rts           ;----------
I2CTx1: sta     SRS
        bset    i2cDta,PTCD      ;Tx 1 bit from Carry, init Hi
        bcs     I2CTxH           ;Carry set: go clk
        bclr    i2cDta,PTCD      ; else: set data Lo
I2CTxH: bsr     I2CClk
        bset    i2cClk,PTCD      ;clock set
        bsr     I2CClk
        bclr    i2cClk,PTCD      ;clock clr
        bsr     I2CClk
        bclr    i2cDta,PTCD      ;put data Lo
        bsr     I2CClk
        rts           ;----------
