I need help about 68HC705C8
Gabriel_Markez
I need read EPROM/OTPROM (PROM) in order to  program other 68HC705C8.
How can I do it ?... Can I Build a Reader/Programmer for the 68HC705C8 MicroController? would you recommend what software to use?...
MidonDesign
I have a programmer schematic and DOS programming code available on my website at:
Mitch
peg
Senior Contributor IV
Hi Gabriel,
You can read all about this, along with programmer circuits in the devices data sheet.
MC68HC705C8A.pdf
which can be found here:
However if the security has been set, none of this will help you read the contents of the PROM.
