How to trace interrupts in Code Warrior for HC08  v5.1
2,684 次查看
tupham
Dear all,
I am debugging Code Warrior 5.0 for HC08 program. If anybody know how to trace interrupt functions in Code Warrior, please help me.
Thanks so much.
Tu Pham.
标签 (1)
1 回复
1,223 次查看
Bud
Locate your interrupt jump vector table.  I don't know how you have set yours up, however you might want to look into mcu_init.c.. you can see from the jump table, the names of the different interrupt routines and you can set a breakpoint in the routine you are looking for.
An easier way might be to make a file called isr.c and include your interrupt jump table there as well as all the interrupt service routines you want.
Bud
