How to suppress assembler warnings?
namfuak
Is there any way to temporary suppress HCS08 assembler messages in assembly code, like #pragma warning does in C? -WmsgSd is not good, because I don't want to disable the warning totally, but for a specific code region only
peg
Senior Contributor IV
The method to suppress messages from an assembler would be specific to the assembler used.
If you are using Codewarrior then you should be posting this question in the Codewarrior forum.
