How to do Flash Programming on MC9S08GB60
2,701件の閲覧回数
daveking
Hello all, I am currently working with MC9SO8GB60... This is my first time and I am noobs with this microcontroller progamming.  I need to do program in flash, because there is no enough memory in RAM.. Usually I code and modified the script in a file named "wireless_uart.c".
My question is, how to do the flash programming step by step from the beginning? which file I have to open? what should I do? and so on..  I know this is a frequently asked question, and has been answered so many times, but after read some answer regarding to this kind of questions, I still haven't get the idea yet..
David
2 返答(返信)
1,799件の閲覧回数
daveking
Hi Tom, thanks for answering my question.. I already download these AN2295.pdf and the software archive.. now I am still looking at it..
best regards,
David
1,799件の閲覧回数
J2MEJediMaster
Specialist I
You'll want to look at Application Note 2295, which has information on serial bootloaders. Type 'AN2295' into the Enter Keyword box at the upper right on this web page and you should get references to both the application note PDF file and the software archive with the code.
---Tom
