How to configure an 802.15.4 Router?
UC3MZigbeeGroup
I need configure a FFD how a normal coordinator or router. I configure it, but after the device does not transmit any packet, I suppose the configuration is wrong.
 I have attached the code that I use to configure the device how a router. Can you say me what is wrong?
I am using MAC Codebase 1.0.2 and my application is based on “MyWirelessApp Demo Non-Beacon (Coordinator)”
Thanks in advance.
AlanCollins
Contributor V
802.15.4 does not implements NWK layer. Routing is not possible, unless you develop a NWK layer on top of the 802.15.4 MAC.
Spell
Hi UC3M,
I'm trying to configure a FFD to be a router using MAC codebase but unfortunately it doesn't forward the packet. Have you correctly configure a router?
If yes, can you say to me how?
thanks,
filippo
UC3MZigbeeGroup
Hi Spell,
I'm sorry that I can not help you because I did't had still achieved to configure the device as router.
Best regards.
