HCS08GT16a Softec debugger illegal breakpoint
GPS_Buoy
Hi,,
I have a problem with HCS08GT16a processor, when i go to debug the project, The True-Time Simulator window opens, the code is downloaded into the flash then instantly reports an ILLEGAL_BP. The strange thing is i never had this problem with this exact code when working with it earlier. Also i have no breakpoints set. I can not find why this may have happened. Can anyone help me with this problem?
fabio
Are you sure your target device is properly set as GT16A ?
Any modification on the PRM file?
Message Edited by fabio on 2008-08-08 11:36 AM
