HC908 + GPS
HC908 + GPS
2,359 次查看
ElliottKevin
have anyone implemented an GPS Latitude/Longitude to UTM algorithm in a HC908 uC?
If so, do you have a source code or a guide to work around?
Thank you
1,914 次查看
ThaManJD
no.
I hadn't even heard of UTM co-ordinates before your post.
It appears to be a network of alphanumerically notated grids and a coordinate is then notated in metres within the grid with a reference at a particular corner?
Besides military, what other systems use this method?
From the sounds of what wikipedia says there's odd considerations for coordinates near grid lines and strange exceptions for some areas in Europe.
JD
1,914 次查看
ElliottKevin
very well!!!
__________________________________________________
complete strut assembly
shocks and struts
Shock absorber
