Globals vs. Locals for ADC.
FWFan
Hi All,
I tried to use global (before main) to hold my ADC capture but it does not work.
But if I use local, the ADC result would be stored sucessfully.
Do you guys have any thoughts?
The reason I need to store my ADC globally is because I will need
to transfer it when I do my IIC isr.
I'm including my code for reference.
Thank you,
FWFan
eckhard
maybe it helps to declare your global variable as volatile
Eckhard
FWFan
Thank you Eckhard.
I will try that tonight.
FWFan
