F2952X0700
F2952X0700
9,449 次查看
info37
Hi is there a way we can read this IC what we need is the eeprom data for this IC or we can have the data sheet to read the IC.
With one of my reader  it says :
Transponder: HITAG 3 unknown
Encoding: Biphase
Equalizer: Regular
CryptoKey: Customer (Locked)
I would like to read the remote data of the IC.
6 回复数
7,691 次查看
Fuzz
Hi.
Has anyone managed to read that chip? Or can anyone help or guide on how to read that chip please?
9,279 次查看
info37
i have checked its a NCF2952 Keyless Go Transponder IC thats what i am interested to read in.
8,300 次查看
Gilles13112
J'ai le même problème, mais aucune info sur le net.
Moi c'est le CI f2951x0700
Le transpondeur est verrouillé et impossible de lire les données.
Je pense qu'il faut se servir du protocole I2C via des tests points .
Comme je n'ai aucune info je suis bloqué
7,434 次查看
NamatJawadi
It have 4 pinout for read. My tool can not read it. Any tool sugestion for try to read?
7,434 次查看
NamatJawadi
Hello. I have remote with this ic. Can u lock with vvdi. For reuse the key.
But i want to copy past data. What tool can ready the data?
7,395 次查看
Fuzz
I think you can lock the remote with a remote programmer like autel km100. However reading it and unlocking it seems to be a problem. I have not yet found a solution for that
