Example code for the MC9S08PT32VLH
BPR
Iam looking for an Example code for the MC9S08PT32VLH board but can only find assembly code examples in Code Warrior. Where can I find the example codes in c, particularly I want UART related code to check serial logs.
BPR
Hi RaRo,
I don't have that dev board with me. I have a custom board which has MC9S08PT32VLH which is of 32KB Flash Memory.
If you have any idea about examples (in C) specifically reated to MC9S08PT32VLH kindly let me know.
RaRo
Hello @BPR,
Unfortunately, there is not an example in C for the MC9S08PT32VLH about how to use UART. Nonetheless, you could use the information above or the following link as a reference to your implementation.
We apologize for any inconvenient this may cause you.
Best regards, Raul.
