Ethernet Interface - MC9S08LC60
3,049件の閲覧回数
tcp_ipstack
         I am using DEMO9S08LC60 board,here the contoller used is MC9S08LC60,
for my application i want ethernet interface,there is no onchip ethernet interface for
this controller,is it possible to interface ethernet to this controller by using general
I/O lines,if so how to interface,pls guide me i am new to this.
Thank you
Added p/n to subject.
Message Edited by NLFSJ on 2007-12-19 09:39 AM
1,612件の閲覧回数
Bruce_andrew
You probably should investigate other MCUs. Ones that have ethernet on the chip. Have a look at Coldfire, some have the PHY onchip too, so the total solution is cheap.
1,612件の閲覧回数
tcp_ipstack
Thankyou for reply,
       I have found enc28j60 ethernet controller,it is having
Integrated MAC and 10BASE-T PHY,how to found the
tcp/ip stack for this.
