Endpoint  bulk  in jb 16.
2,176 次查看
fredycolombia
I have used testhid in jb16 to sending any data through  usb interface.
I only put  dato=PTA, and then I put it on   KbBuffer[0]=dato. The problem is that the data mean rate is to slow (2Kbytes/s) and  I need to increment data rate.
Now I burn TBDML_JB16 and windows recognize like "USB DEVICE" , I have used usbio driver and this identify endpoint like bulk.   I want to send it data through  usb without use bdm in this firmware, but I don't know where I can put "dato" or how to do the same as in  testhid  to send any data through usb.
I attach firmwares and  images about my problem.  I appreciate your help.
regards
Fredy.
firmwares_and_jpg_bulk.zip
Message Edited by t.dowe on 2009-10-19 10:46 AM
1,425 次查看
JimDon
Senior Contributor III
You need to change bInterval in the endpoint descriptor.
- descriptor's bInterval value indicates the requested maximum number of milliseconds between transactions.
I highly recommend you get a JM60 Demo board and go with that. The generic hid demo pumps data quite well and the CDC demo work at 115K baud.
1,425 次查看
fredycolombia
Hi jim,
Thanks for answer, I  have already JM60, and I agree  with your suggestion, I think is a good  mcu to use usb.
regards,
fredy
Message Edited by fredycolombia on 2008-02-16 01:01 PM
