DZ96 & DZ128 - any info yet?
2,082 次查看
Bruce_andrew
Does anyone know much about the DZ96 & DZ128 yet? I assume it's in development still.
Datasheet available?
Pricing available?
Product available?
If not, then perhaps someone can let me know when the answers to the questions above will be available :smileyhappy:
标签 (1)
1 回复
1,232 次查看
Nabla69
Contributor V
Hi Bruce,
You won't find any pricing on the Forum. As they change it's not really their place to be on a static form.
If you search the forum, there's a link to a page for the S08D datasheet.
If it's not there, then you can't have it publicly.
However, if you work as Alpha customer or have a NDA with FSL, you can try and ask your Field Applications Engineer from FSL or your distributor.
Cheers,
Alban.
