Compile to .s19 file???
2,631 次查看
utt
I am working with HC908AB32 micro-controller and we'd like to use CodeWarrior for development. I have successfully created a small demo program (blinking LED) for the micro-controller, however, my programmer requires a .s19 file to write into the chip. How can I compile the source code into this format?
Thanks.
Message Edited by utt on 2007-02-2110:11 PM
1,525 次查看
peg
Senior Contributor IV
Hi utt,
In the bin directory under your project, you should find a file named Project.abs.s19
This is what you are after.
1,525 次查看
UcTechnoGeek
Fresh Out Contributor
Also, under the project settings -> linker -> options tab, there is a check box for creating an S record file.
uCTechnoGeek
