Compatibility MC13191/92 SMAC
3,338件の閲覧回数
xevi
I'm making a new design using SMAC and MC13191. It doesn't work, but when I remove the tranceiver MC13191 and put MC13192 it works. I've found in the SMAC code that it reads/writes registers that only exist in MC13192. Should I change any #DEFINEs? Can you suggest any reason why it doesn't work with MC13191?
Thx a lot!!
1,269件の閲覧回数
xevi
I'm sorry, I've found the problem!!
 1 pin of MC13191 was broken!! I solder other MC13191 and it works!!!
thx!!!
