Codewarrior 10 - disabling step into interrupts
Nik
When I debug in CW 10, I am stepping into interrupts.  This is easily disabled in CW 6.3, but I can't find a way to do this in CW 10.  Anyone know how to do it?
Also, the floating license allows me to compile, but when I run/ debug, I get:
"Target request failed: Download size limit has been exceeded. Please check your license.
 limit has been exceeded.  Please check your license."
I am using a temporary license.
bigmac
Specialist III
Hello Robert,
How is this done with CW 6.3?
Mac
Nik
In the debugger, MutlilinkCyclonePro->Disable interrupts while stepping
CarlFST60L
Senior Contributor II
Where is this option in CW10.1?? I have looked for 10 minutes and can not find this!!!
The help menus show it as interrupt mask level under debug options, but that tab is not even there for me!
Nik
I am using CW 10.2, but I think it is the same for CW 10.1:
Debug configurations, Debugger->interrupts->Disable interrupts during stepping checkbox
See attachment
CarlFST60L
mmmm, I dont have that tab... Awesome..
CrasyCat
Specialist III
Hello
  This feature is not available in v10.1.
  It has been added to V10.2. So you need to upgrade to CodeWarrior MCU V10.2.
CrasyCat
CarlFST60L
Thanks :smileyhappy:
