Can we use multi-link programmer tools to program MM9Z1J638BM2EP?
If yes, can you tell me a software tools that support like this, please?
解決済! 解決策の投稿を見る。
I do following on previous post as link below. the failure is gone. So for my conclusion of this failure.
we need to add a capacitor 470uF connect between #RESET (pin 2) and GND (Pin 4) for protect the analog die watchdog issue.
HiYes you can use the Multilink to programm it, and you can use codewarrior 11 as IDE.
Hope this will help you.
Ok, I will try and update result soon. Thanks
We found the device can't erase due to device is secure and we click "yes" the software has show figure 2 and then we did follow the message show, the figure 1 is repeating and we re-do again. the result has show on figure 3. how are we gonna fix for this failure?
Figure 1
Figure 2
Figure 3
Did you perform a power cycle? you need to unplug the device and the multilink that plug again and retry.
I hope this will help you
Yes, we did either multilink and the device the message still failed as picture below.
