Can't Flash Programming my 13192-EVB
3,705 次查看
LC
 Just got my 13193EVK Kit.
Trying to run the 'Range Demo Plus' Demo on 13192EVB boards as described in the User's Guide.  But when I power on the 13192EVB boards (2 of my 3  boards), not all four LEDs are on.  According to the User's Guide, this means that the PTC application is not on the board.  So I tried to use the Embedded Bootloader to load it.   I followed the procedures described in the User's Guide ( section 5.7.2) :
   hold down all four buttons ( S1-S4 ), press and release the Reset button, then release the 4 buttons,
   But the 4 LEDs just blink once ( not staying ON ).
  Please help.
标签 (1)
2 回复数
1,803 次查看
reundo
try holding down just switches 2 and 4 that does the job sometimes.
1,803 次查看
Tarek
Senior Contributor I
I suggest that you buy the BDM programmer it is easier and faster to use
