CW assembler ORG problem
donw
I am using Code Warrior to assemble assembler code only
I what to position a table on the next 256 byte memory boundary after my code
Other assemblers will allow:
  ORG   * & $0FF00
  ORG   * +$100
but CW says 'complex relocatbale expression not supported'
How can I do this in CW?
don
donw
thanks
My code also works now.
I added
XREF _Startup
to my list of vectors (@ fffe) , and it now assembles!
bigmac
Specialist III
Hello Don,
I have successfully used the following construct for CW absolute assembly -
  ORG ((*/$100 + 1)*$100)    ; Start new page
The whole expression does need to be enclosed in parenthesis, as shown.
Mac
donw
thanks
I added
XREF _Startup
