CODEWARRIOR SPECIAL EDITION STARTING
BIGMAN
I download the special edition of codewarrior for HC(S)08 V6.3; but I can not start the software.
when I try to start, I have a message saying that windows has found a problem during the starting of codewarrior so it will stop.
I am looking for solution for this problem.
Thank you
J2MEJediMaster
Specialist I
We need a little more information that "it does not start" to figure out what is going on.
What version of the OS are you using? What is the exact error message?
There are issues with running CodeWarrior on 64-bit operating systems. Please check in the CodeWarrior forum for some solutions, or do a search on "64-bit".
---Tom
