CLK and TPM
已解决
CLK and TPM
跳至解决方案
3,229 次查看
carlosomarharoc
Hi.
Im using a MC9S08MP16 microprocesor
i dont have idea how to use the intern clk and how do a TPM for generate a PWM at 60Hz
I´m new with code warrior.
标签 (1)
标记 (1)
1 解答
3,011 次查看
david_diaz
Hi Carlos,
Please find attached to this response a PWM Sample code for your device.
Besides that I recommend the following material in order to a better understanding of the TPM Module:
1. MC9S08MP16 Reference Manual, Chapter 12:
http://www.freescale.com/files/microcontrollers/doc/ref_manual/MC9S08MP16RM.pdf
2. S08 TPM Interface Module course:
S08 TPM Interface Module|Freescale
Hope this information will be useful for you.
Have a great day ! :smileyhappy:
在原帖中查看解决方案
3 回复数
3,011 次查看
david_diaz
Hello Carlos,
What version of CodeWarrior are you using?
I would like to know your IDE version in order to give you a PWM sample code.
As you are using an 8 bit MCU, you can program it with the Classic CodeWarrior version (6.3) or with the current version (10.6).
David
3,011 次查看
carlosomarharoc
Hi David. Is the current version 10.6
3,011 次查看
david_diaz
Hi Carlos,
