C language programing
Nicol_s
I'm a beginer in microcontrollers programing, and I only use assembler code. Please I need some examples for c aplication or send me some information to my e-mail ([email protected])
lucyperek
If you really want to write the most efficient and reliable programs stay in assembler. Sometimes it gives you a little bit more torment but pays back with shorter debugging and your full awareness how the program works.
nucklear
May be you can check the "Learn Programming with C" course from CodeWarriorU:
http://www.embeddedlearningcenter.com/freescale/publish/COURSE27448/Learn_Programming_with_C.pdf
You can also check this application note (Getting started with HCS08 and CodeWarrior using C):
http://www.freescale.com/files/microcontrollers/doc/app_note/AN2616.pdf
Nicol_s
Can you send me a simple led destellator in C lenguaje using a MC68HCJK3 microcontroller in CODE warrior compiler. Thanks a lot. NICO
