Bug in Z-Stack?
Bug in Z-Stack?
2,868件の閲覧回数
Zap
Hi everybody,
looking at this lines of code found in ZDApp.c
case ZDO_NWK_DISC_CNF:
  if (devState != DEV_NWK_DISC)
#if !defined ( ZDO_COORDINATOR )
  else if ( (msgPtr[1] == ZDO_SUCCESS ) &&
      ( zdoDiscCounter++ > MAX_DISC_ATTEMPTS ) )
    devState = DEV_NWK_JOINING;
I can't understand why  (zdoDiscCounter++>MAX_DISC_ATTEMPTS).
According to me following this code a device or a router won't join the network unless it recive more than MAX_DISC_ATTEMPTS succesful discoveries notifications.
I changed the statement with (zdoDiscCounter++>MAX_DISC_ATTEMPTS) and it worked well.
Is this a bug or there are any reason to justify this choice?
Thanks!
1,383件の閲覧回数
Zap
sorry, cut&paste error!
I meant I use this expression:
(zdoDiscCounter++<MAX_DISC_ATTEMPTS)
