Bit Banging on MC1321x-SRB
4,339 次查看
ppanicker
I want to interface MC1321x-SRB to CS5463 which is a power IC to measure apparent power, using software SPI.
Can somebody help me out with this? Can you tell me which pins are required to to achieve software SPI and also small snippet of C code.
Thanks in advance
2,790 次查看
peg
Senior Contributor IV
Perhaps if you tell us what was lacking in the results you obtained by putting the words "bit bang SPI" in the search box at the bottom of the page before you made this post, we might be able to assist you more accurately.
4 回复数
2,790 次查看
ppanicker
Hi Peg,
Can you help me with a C code snippet? I want to be able to set the CS5463 SPI module timing parameters using the GPIO lines of HCS08. And then read from a register of CS5463.
Poornima
2,790 次查看
bigmac
Specialist III
Hello Poornima,
If you use the search box as Peg suggested, it is possible that you will find the sample code snippet that you require.
Mac
2,790 次查看
ppanicker
I want some C code, to get myself started with CS5463, to read any register value of IC5463 and also to set the SPI timing parameters correctly.
Poornima
2,791 次查看
peg
