Antennas for Zigbee radios
kbu
I am trying to design a very small sized zigbee board, and could use some inputs on designing the antenna.
chip antennas seem to be the only ones that will work with my app given its size.
Has anyone specifically used the ACX - AT 9520 Series as referenced by freescale in AN2731?
I was wondering if anyone had any experiences they could share on designing these or other chip antennas into their boards?
- Are there reference notes, from which I could literally cut and paste the design into my board?
- Have you maybe gotten this board FCC certified?
- Where do you source the ACX chips from (they don't seem to have any northamerican contacts)
Thanks.
Samram
The manufacturer of the chip antenna AT9520 is:
ACX
Advanced Ceramic X
TEL :+886-3-5987008 ext 292
FAX :+886-3-5987001
Mail :[email protected]
Website: www.acxc.com.tw
Address :ACX Corp.
16 Tzu Chiang Road, Hsinchu Industrial District, Hsinchu Hsien,Taiwan,330
I used this antenna as referenced by Freescale and thre results was satisfactory, (same sight distance if you compare it with SARD boards). Complete P/N of this antenna is: AT9520-B2R4HAAT/CF
SamRam
Wings
You've probably already found what you're looking for by now, but just in case you haven't, try looking at Linx. They make transceiver modules and a line of small antennas.
http://www.linxtechnologies.com/index.php?section=products&category=antennas
