AN3927 problem device cannot start with JM60
2,022 次查看
eduardo1
Hello, i'm trying to use USB MSD bootloader with JM60 but when i connect the microcontroller to the HOST there is a message "device cannot start(code 10)" . Anyone had the same problem? How can i solve it?
I'm using Code warrior 6.3, AN3927 code reference and windows 10.
1,949 次查看
vicentegomez
The AN3927 is old, and there is not a new version for it, you can check the recommendation on the following thread
https://community.nxp.com/thread/318424
Also codewarrior 6.3 is not recommended to run on windows 10, maybe you also have some problem with the windows driver
