AF_DataRequest and memory management
CecchiSandrone
I want to know what's the memory management of buffers while calling AF_DataRequest because I'm encountering some "out of memory" errors from it. Who is responsible to free the buffer?
Mads
Cecchi,
you question is very general and would not be easy to answer.
I would recommend that you re-visit our documentation and read how the AF_DataRequest should be used.
But, to try and solve you issue:
When you do a AF_DataRequest, wait for the confirm before you initiate the next transmisison.
This will insure that you do not stavate the system.
BR,
Mads
CecchiSandrone
BR,
Mads
Yes Mads, I understand this. I can't catch only who is responsible to free the buffer that contains the message to send. Furthermore, is there a "unreliable" way to send data without waiting for confirm?
Mads
when you "pass on" a buffer, the layer you pass it to is responsible for the free'ing.
You only have to free when you receive - just like the demo application shows.
BR,
Mads
CecchiSandrone
Ok...now is clear! Thanks again for info Mads.
