ADC converts negative voltage?
1,834 次查看
mmm
Does the ADC convert negative voltage? If so, where is the negative bit stored?
标签 (1)
1 回复
1,013 次查看
peg
Senior Contributor IV
Hi Katback,
Answer: No!
Answer: Not Applicable!
If you have a signal that goes positive and negative you usually use an op-amp to "level shift" it up so that the entire range of the signal now falls between 0v and Vcc
