9S08QG8  serial bootloader
paul
Has anyone modified the 9S08GB serial bootloader AN2295 to work with the 9S08QG8? If so:
-did it work ok?
- are you willing to share your mods?
I want to be able to flash-upgrade a device I'm developing. Is this the way to do it?
Thanks...
peg
Senior Contributor IV
Hi Paul,
If you had taken a bit of a look around before posting, you could have found it for yourself. See here:
http://forums.freescale.com/freescale/board/message?board.id=8BITCOMM&message.id=921
BR Peg
paul
Thanks Peg
