36 to 13 pin
36 to 13 pin
985件の閲覧回数
hosseings
hello every body. I saw a mini ECU board that had 36 inputs. But only they use 13 pins of a micro controller. every 4 inputs goes to an optocoupler ic, every input has two pin at output, one of them connect to a diode package and the output of diode connect to micro, another connect to same pin in other optocoupler ic and then connect to a micro input pin. how it works?IMG_20180204_223432.jpg
0 返答(返信)
